Halogen Bulbs
kooboy
Sorry the title was wrong, Did anybody changed to xenon headlights on corolla verso? Are they worth changing? if i buy on eBay do they serve the purpose and which model i need to buy?
Thanks :huh:
Hi nobody here to suggest? :crybaby:
Do I need HID converter for the 2004 Nov model verso? or I can straight away change the bulbs?
Somebody help me please.
Finally I've replaced my bulbs with xenon filled. This gives stunning light.
So did you need to do anything other than buy the bulbs and stick them in?
I am thinking about doing the same, which make and type did you buy?
Please let us know,
Andy.
No, you just replace them straight away. It's easy to insatll if you see the verso manual.
Why did you need to fit xenon filled bulbs? What I am finding on my Verso is that the aim of the beam on both dipped and high beam setting is too low. The dealer says they cannot be adjusted. Does anybody know different?
Why did you need to fit Xenon filled bulbs? What I am finding on my Verso is that the aim of the beam on both dipped and high beam setting is too low. The dealer says they cannot be adjusted. Does anybody know different?
I just want to have white beamed lights. I thought instead of going for expensive HID installtion. This is cheapest option. I don't have any problem so far. The light is good compare to the yellow halogen light.
