Rav 4 D4d 2003 Injectors Air Flow Meter
mark c
Hi all this is my first time posting. I have had a 2002 rav 4 2.0 d4d for two years and all was fine until the usual happened poor running, flat spot at 3000 then going on to limp home. Dealer diagnosed new injectoirs needed and air flow meter. So purchased them and fitted them. Car still exactly the same. Have now removed the parts back off the car after 150 miles of running, so if anybody is needing as set of as brand new injectors part no 23670-27030 and denso no 0950200-0570 or an air flow meter part no 22204-27010. These part are available at a massive saving from dealer price. If it can help you please reply.
Mark C.
Hows you got on? Car fixed?
No got fed up problem that nobody could pinpoint, so have traded car in.
Mark C.
hi Mark
the main possible reazons of yr problem are asf:
- poor injection;
- fine filter clogging;
- T/C performance (depends on item 1);
- injection timing;
- condition of yr air filter;
- control system ffor your injectors (in case they are solenoir controlled);
- compression rate in each cylinder.
Mr T has just offered to change minor links in the problem chain.
Cheers/Igor
Shame.
I've found that good mechanics are few and far between - and those good ones are booked up for weeks in advance.
What have you got now?
  • 4 weeks later...
  • 1 year later...
Mark C.
Hello
Have you already sold your injectoirs?
In case of they're always available, I'm interested in it
Could you give me the price you want to sold?
Thank you very much for your answer
Eric
I know its a bit late for it but when u fit new injectors to any d4d engine u have to set the "injector compensation code" , its a long number on top of it and save it in the ecu if u don't do this the car still thinks it has the old ones in and it will give same probs going on what has been said it sounds like that has what has happend
