New Sort Of Spark Plug Saves Fuel
uumode
take it with a pinch of salt! all any plug does is initiate the fuel burn, once that has started it is all down to charge swirl and chamber profile, a plug on its own wont make any difference, unless a defective or wrong grade plug is used. think of it as a pile of dynamite it dosnt change the explosion whether you light it with a match or a blow lamp.
only in high performance turbo cars running massive boost can a plug help but then its only misfires caused by the cylinder pressure blowing out the spark or carbon fouling when under light throttle 'cool' conditions.
hope this helps
