Hi I am a new member living in Malta. I have just purchased a Japenese import Toyota Sparky 2001 model is it possible to obtain a English vehivle Hand Book ?
not sure.
I must admit that this is one I've just had to google for, never heard of one before.
Over here it's the Daihatsu Extol apparently. No idea if a book is available except maybe direct from the dealers.
Hi david I am posting some info so that you can download from toyota directly. good luck
he following are instructions on how you can efficiently download content from the
Toyota service manual website (TIS) at http://techinfo.toyota.com:
REQUIREMENTS:
Internet Explorer 5.5 or better (NO, firefox will NOT work on their site)
Notepad
Some sort of "site scraper" or "off-line downloader" tool
A simple understanding of HTML
Adobe Reader
About 1 hour per entire service and electical manual to download and process
First, sign up for either a day pass ($10 USD) or a monthly pass ($50 USD).
Next, select the Make (toyota/Lexus), Model (Tercel, Echo, etc) and year. Be aware
that cars come in generations, so the 2005 manual may really cover 2003 to 2005 without
majors changes. Next select the major section of information - Repair Manual and
Wiring Diagrams being the most common - select only one section at a time. Click
the SEARCH button.
In the right hand pane, a section and subsection search will be returned. If you click
FIND without selecting any specific section and the search results return 250 results, then
you will need to select each section individually, otherwise you can harvest all the inforation
with a single search by just clicking FIND. Be aware that for repair manuals, you will have
to download each section, for others like wiring diagrams, you will likely return less than
250 results.
Now that you have your section selected and the results displayed below in the form of a
clickable form, right click anywhere in the bottom section of the pane and right click and
select View Source. The HTML source code will appear in NOTEPAD. You will notice that the
FORM contains links to a perl script. The problem is, that with most "harvest" programs you
can't harvest the data beyound the form. It turns out it is simpler than that. Normally,
when you click on the form option, it will run the perl script and that script pulls up the
actual PDF file. Really all the perl script does is to re-write the requesting URL of the
perl script to that of the direct PDF file you want. The format of this switch is:
/cgi-bin/ns-data-display_pl/,0/r1/ileaf/DIRNAME/rest/of/it/FILE.pl
to the literal address of the PDF:
/ileaf/DIRNAME/DIRNApdf/rest/of/it/FILE.pdf
------- So, an example would be the perl script of: ----------------
/cgi-bin/ns-data-display_pl/,0/r1/ileaf/06toyrm/06rmsrc/avalonsr/00100110.pl
converts to the direct link of:
/ileaf/06toyrm/06toypdf/06rmsrc/avalonsr/00100110.pdf
or the entire URL would be:
http://techinfo.toyota.com/ileaf/06toyrm/0...sr/00100110.pdf
So, all you need to do is lop off the first five letters of the directory name (06toyrm in this case)
and add the letters PDF. Then chop off everything before /ileaf and replace it with
So, the trick is to open each one of the sections of HTML, copy and paste the sections that
start with <OPTION... into a blank notepad. You should be able to copy all the sections
in a given manual type. So, if all the "directory names" start with /06toyrm (which stands
for 2006 Toyota Repair Manual), you can cut and paste all those <OPTION.. lines into a single
HTML file. When you are done, you should have a single HTML file in notepad with nothing but
lines that start with <OPTION. Next, using search and replace in notepad, we will correct all
links to make them valid.
First, replace all the sections of the following:
<option style="color:#302B75; background-color:#E7E7E7" value="/cgi-bin/ns-data-display_pl/,0/r1/
with
<A HREF=http://techinfo.toyota.com/
Second, replace all the sections of the following:
<option style="color:#000000; background-color:#DBD0D0" value="/cgi-bin/ns-data-display_pl/,0/r1/
with
Third, replace all of the following:
.pl">
with
.pdf>
Fourth, add the directory information (see above on how to format):
/02toyrm/ (NOTE: THIS IS ONLY AN EXAMPLE, ADJUST TO YOUR DOWNLOAD FORMAT)
with
/02toyrm/02toypdf/ (NOTE: THIS IS ONLY AN EXAMPLE, ADJUST TO YOUR DOWNLOAD FORMAT)
Now you should have lines of text that look like the following:
<A HREF=http://techinfo.toyota.com/ileaf06toyrm/06toypdf/06rmsrc/avalonsr/00200910.pdf> R.M. 2006::Preparation: 2GR-FE Ignition: Recommended Tools, Equipment (Avalon)
So, you can see that what you have done is to create a HTML reference so that when the text
is clicked (R.M. 2006::.....), it will bring up the correct PDF file. It also creates an
entire table of contents so that you don't have have a bunch of .PDF files sitting in
a directory. The problem is that you will notice that the end of the text is missing the
</A> which indicates that the text link has ended. So, you should notice that the model
of the vehicle is listed at the end of the line for each and every line. So, next you
will need to do a search and replace as follows:
(Avalon) (NOTE: Your vehicle will vary)
with
(Avalon)</A>
Now you have a fully formed link. To make sure your links work, take a random link URL
such as the one from the URL above:
http://techinfo.toyota.com/ileaf06toyrm/06...sr/00200910.pdf
Log into the TIS website and then copy and paste the URL into the browser bar. If
everything has worked correctly, then you will see the requested PDF file come up. If
you don't see it appear correctly, go back and re-read the instructions.
Save your newly created text file as something like "2006 AVALON REPAIR MANUAL.HTML".
Now you have a HTML file that has all the links to the PDF files. Since this is
only useful if you are connected and logged into the TIS website, you want to create
an off-line copy of all the data those links point to. So, you will need a program
that can create an off-line duplicate copy of your HTML file with the PDF files. I
use OffLine Explorer from Meta Products (http://www.metaproducts.com) and you can
download a 30-day eval copy of their product at:
http://dl.filekicker.com/send/file/167624-8K67/oesetup.exe
Set it up (you'll have to read their instructions on how to do this... it isn't THAT
hard to do) with the "website" you are downloading to be the HTML file you created.
Download the entire website, including the PDF files to your local machine. Keep in
mind that when downloading the content, you HAVE to be logged in with the credentials
for the TIS website. In OffLine explorer, you can surf IE "inside" their offline
browser, so all you have to do is to log into the TIS site, and once in, select to
download your "website" file. It should take a few minutes to download all the PDF
files. If you have a problem here, it is likely becuase your offline browser program
isn't properly logged on to the TIS website when you started the download.
Once you have the download complete, there is usually an "export" option that allows
you to save it to a "CD ROM". This will download all the content and then adjust
the HTML file you created to have pointers to the local drive where the off line
content was downloaded to (and put into seperate directories).
At this point you should have a complete replica of the TIS website content on your PC.
If you take the time to download manuals, please also take the time to share your
content with others on bittorrent. Sharing is simple and doesn't take more than 10
minutes once you've done it a few times. To learn how to share content, try this
site:
http://www.demonoid.com/faq_creation_utorrent.php
Thanks,
  • 2 years later...
REQUIREMENTS:
Notepad
Adobe Reader
the SEARCH button.
250 results.
with
with
.pl">
with
.pdf>
with
with
(Avalon)</A>
site:
Thanks,
Hi David
looks like you live in Malta i need some parts for my Toyota Sparky E.G Electri Window door switch complete unit also i would like to buy a Remote control key with codes as my sparky came with normal key but has the remote option where would be the best place in Malta to get these parts.
Tks Nigel
