Brakes
Omasis`
Iv started to noticed a slight grinding noise coming from my brakes so i have a few questions. Firstly my car is a 04 CTS
1, What are the best brake pads to buy for the cheepest money?.
2, Are they easy to change ie do i need brake keys etc?.
3, Are brakes usually covered under warenty as i have an extended one on my car with The AA?.
Any answers would be greatly appreciated.
best and cheap dont really go together!
which pads depends on what you want to achieve and they wont be covered under warranty. if you need a hand or someone to show you what to do give us a shout and i'll pop round.
Mike
i just bought some brake pads from euro car parts for £20 not bad just checked my ones on me car at the moment and they seem fine which is wierd, it might just be the back ones that are worn i think im gunna replace them anyways if you could show us how to do em it would be great mate and it would probably save me an hour
no worries mate, next time you need some parts i'll introduce you to where i go - bit cheaper than euro parts and they do really good prices on blueprint parts. Its a quick job on the pads and simple once you've seen. i'm at work this weekend but can come and see you one evening next week?
Brakes Hmmmmmm well i dont know much but i do know this, they will not be covered under warranty and if you get toyota to do it they will screw you over and charge you £600 quid to replace them, I would of thought if you dont stick with origionals your warranty may be invalid could be well off the mark here.
Changing your brakes doesn't affect you warranty in anyway. As it's general wear and tear.
I've added new brakes all around, Induction kit, alloys and lowering springs and it hasn't effected the warranty at all. :P
I actually need to change my brakes on the front at the minute. I'm thinking of EBC Redstuff Pads all around + EBC Vented Discs, Totals £117 including delivery. Can fit myself so no labour charges.
I've added new brakes all around, Induction kit, Alloys and lowering springs and it hasn't effected the warranty at all. :P
Hello mate where did you get that price of £117 from? Is it from a website?
Cheers
Alright bud,
It's from here.
EBCBrakesDirect
They're called EBC Brakes Direct but are just suppliers, not actually EBC themselves! The £117 includes a 10% discount + free standard shipping.
So if you want next day you have to pay an additional couple of £. :thumbsup:
Just went to change my pads and there is plenty left on the old ones, i took the pads off and checked the discs for grooves and the hole disc is wobbleing/loose is it suppose to be like this??
Just went to change my pads and there is plety left on the old ones, i took the pads off and checked the discs for grooves and the hole disc is wobbleing/loose is it suppose to be like this??
was the wheel off ? what do you think holds the disc on..........
should have just changed them anyway? the pads start to make a noise when only half worn - but thats the time to change anyway. not worth letting them get low.....
theres about 2.5 - 3cms left on them at the moment its just the disc thing is scareing me at the moment
the disc will move with the wheel removed - that's what i was implying! i'm at home at the mo if you want me to double check for you
Alright bud,
It's from here.
EBCBrakesDirect
Is that for front and rear discs and pads?
Cheers
H
Alright bud,
It's from here.
EBCBrakesDirect
Cheers
H
Front Discs +Front Redstuff pads.
Rear would eb another £100 on top or so.
