Alarm Problem
diamond1979
hi again my alarm makes no noise when it goes off all lights flash but no noise any ideas
cheers :wacko::unsure:
The speaker part of the alarm might have become disconnected or damaged. I dissconnected mine on purpose as the alarm kept going off for no reason even half way through a drive. In the gen 7 it is located in front of the panel you remove to change the rear light bulbs. If you know where it lives on your motor, a good place to start is by checking the connector for it.
