Hello there, Firstly I am not a computer genius so please help me out, I bought a Toyota Granvia 3.0 TD last year and have now bought a English user manual. Very recently I put four new tyres on as they were totally goosed. The tyres speed rating that was on was incorrect and that may have had something to do with the condition of them, however they now have the correct load and speed rating. My problem is this, I want to check the wheel alignment on the Granvia but my local garage cannot programme their machine as they don't have the data. I have contacted Toyota and they don't have it either (strange) but they suggested I join the owners club for help etc etc and here I am. I would really appreciate it if someone out there has this information and would like to share it with me. Best Regards. (Frustrated)
  • 3 months later...
This may help:
Granvia Tracking
Toyota Japan Import: Granvia/Ipsum: H10Series : RCH11W. KCH10W
CAMBER FL -0.50'~ 0.40': FR ditto. RL -0.30'~ 1.00 RR ditto
CASTER FL 1.00'~ 2.30' : FR ditto.
TOE FL 0.0~2.0mm : FR ditto RL ditto RR ditto
SAI FL 9.50' ~11.20' FR ditto
INCLUDED ANGLE 9.00' ~ 12.00' FR ditto
FRONT
Cross Camber -0.30'~ 0.30'
Cross Caster -0.30' ~0.30'
Cross SAI -0.30' ~0.30'
Total Toe 0.0mm ~4.0mm
REAR
Cross Camber -0.30' ~0.30'
Total Toe 0.0mm ~ 4.0mm
Thrust Angle 0.0' BUT might be 0.01' on a Granvia
Axle Offset 0.0mm
eg
FL= front left
RR+ right rear etc
0.50'= 0 degree 50 minutes
2.30' = 2 degree 30 minutes
Regards,
HI Mike in france thats good data, do you have this for other imports or do you want to disclose where you got it from. I am looking for the data for mine (Mark II) but as crazy frog said dealers cant help.
please inform
thanks
rick
Hello Crazyfrog,
Sorry but I only have the information for the Granvia. I got the information from a tyre dealer who had the latest computerised gizzmo for checking the wheel allignment the last time I was in the UK. I would suggest asking around tyre dealers in your area, the larger ones with the latest wheel allignment rigs should be able to help you.
Regards,
Mike
