Help Needed (gen 7 Gts)
PHILGTS
my car makes a ratchet-like sound when I decelerate in gear.
as soon as I throw the clutch in, it goes away.
as soon as I give it a little gas and it accelerates it goes away.
I'm located in Ontario,
if anybody has any ideas throw 'em at me. I hate the way the car sounds right now.
hi i think i mite have the same prob is it coming from the back end of your car?
no, I ended up trouble shooting it myself, and lo and behold it was a leak at the exhaust manifold. I asked one of the mechanical engineers at work why the ratchet sound would have happened because of leaky exhaust; he replied: when you take your foot off the accelerator, you change the pressure in the engine, which would account for the non-exhaust type sound.
anyways, I tightened the pig down and now she runs like a ghost. hope this helps :)
hey boss, update on my exhaust problem...
now that I have the manifold secured properly, I'm noticing some sounds near the back of the car. it's also idling a bit higher than it did before.
is your exhaust stock? because mine is, and I'm wondering if installing a magnaflow would reduce the back-pressure and in turn reduce that rumble near the back.
I'm just learning about this stuff, so there might be plenty wrong with what I just said. but hit me back and hopefully we can figure this out.
