Squeaky Gear
muttu34
I just had the clutch on my Toyota avensis replaced at Toyota. I noticed that everything works fine on the clutch except when the engine is reved over 3000 rpm. once i get to that rev and press on the pedal to change gear I feel a noise and like a little vibration on the clutch pedal. the higher the rev the higher the noise!
I'm not sure if it's supposed to do that!
Another thing i noticed is some sort of a sqeaking coming from the gear box, but only when I put the gear in first or 3rd gear, i get the squaking even when the car is not moving and engine is off, even when the gear is idle and not in any position and only moving it left and right.
should i take it back to Toyot or is all this normal?
