I Want Satnav On My Toyota Avensis 2005
johnro
hello
i want SatNav on my Toyota Avensis 2005 2.2 D4D 150HP
on the internet i saw this model : TNS700
is it possible to install it on my car? do you know how much it will cost? (aprox.)
do you know where i can find which countries they covered already?
do you know where in london i can get more detailes before i'll buy it?
thanks for all your help
Hi please see below from smoftah
"Hi Yes TNS700 can be retro fitted to your car, instead of TNS310.
It would cost alot as the TNS700 unit will be hundreds from Toyota, you will need a new fascia as the TNS700 also controls all audio and you lose the headunit you currently have, you will need new wiring plus a new DVD map.
Honestly it will be very expensive unless you can get the unit cheap"
refer to http://toyotaownersclub.com/forums/index.php?showtopic=81302
thanks but o saw that topic. that guy had a GPS system already installed. i don't have one.
i guess it's another situation :)
