Yaris Clutch And Pressure Plate Are A Match
Hi today i collected the cluth and the pressure plate from mr t , the yaris 3 cyl clutch is slightly bigger and the pressureplate is too but all the fitting holes match on the pressure plate so when they are fitted i will tell you how much better it is :thumbsup:
Good stuff! I didn't realise the parts were different on the Yaris, but had a look at Steve's the other day and in fact it also has a much bigger radiator even though the engine is the same.
That might come in handy if you need extra cooling, as there is plenty of room under the Aygo bonnet for a bigger rad.
Paul.
Great news indeed! Hope the cluch won't slip now. Waiting on a review :)
maybe the gearbox, differential and clutch of the aygo/yaris 3cyl are the same of yaris 1.3 excluding the aygo's clutch :rolleyes:
By the way, what was the cost?
