Rear Wiper Motor Relay
GS Bert
Hi
Been having a problem with my rear wiper motor, first of all - it started out being on all the time, no matter what position the switch on the stalk was at, now it will not move at all, well it does - when you switch the ignition on, the wiper moves about 1/2 and inch and thats it
Now i have had the motor off and had that checked, it is working fine, now a mate of mine said it might be a faulty relay, now i cant find where the relay is located, looked under the bonnet on the nearside not there i don't think! any suggestions of where the relay is if there is one
or perhaps a better diagnosis of the problem
Cheers Adrian
It's the switches inside the wiper motor housing that are at fault here. If you take the motor out from the rear hatch, then strip it down there is a switch (for want of a better word) built into the housing to auto park the wiper. This just needs a clean up and it'll be as good as new.
Paul
  • 4 weeks later...
Paul
cheers Paul - i'll give that a go
Adrian
