Removal Of Crank Shaft Inner Pulley
gandinefyn
Anyone know how to remove the crank shaft inner pulley. I have a toyota corolla AE92 4 age 1600 and am trying to replace the oil seal. Help!! :huh:
if you mean the one that the timing belt fits on it should just slide off, occasionally you need to remove the front woodruff key
