Clutch Change
delboy21
want to change clutch on my gen 7 celica 1.8 vvti 2000 model does anyone know if i can take out the clutch without removing the subframe underneath i have heard you have to do that seems a lot of work just to change clutch any tech help would be gratefull
Del you can do it without moving the sub-frame, just by removing the cross member. When you drop the G/box, watch for fouling! It makes the job trickier, its easy just to remove the sub-frame. Otherwise, you'll run the risk of putting excessive strain on the mountings trying to get the angle for the g/box drop. Don't be put off by the sub-frame removal job. Its only nuts and bolts!! :D
thanks redneck for help cant the box come up the way
would really like to know the easiest way to take clutch out down the way or up the way the way anyone help
