Coolant Fluid
thainy
my coolant fluid is getting a little low and i was going to top it up then i read the warning label under the bonnet . can i change myself or is it a job for a toyota garage and what sort of price
The top pops off the coolant bottle, just top her up to the max! ***** easy takes 5 seconds...
its long life coolant on them tsports
dont need changed until 100k i think
just fire some water in to top it up and it will be sweet
  • 4 weeks later...
i wouldnt use water.
it will do the job of cooling, but your more susceptible to corrosion, and also freezing in winter.
you need to get the toyota red long life
  • 4 weeks later...
dont use water toyota red coolant is 15 quid for 5litres wudnt change yrsel tho if yr not confident or mechanically minded drain screw is awkward to get at and they can be a pain in the backside to get all t air out if the level was quit low also make sure yr water pump isnt leakin.
any decent garage i wudnt expect to be charging anymore than 40 quid for changing it 4u so becareful of any1 wearin a mask
