Front Splitter And Lowering Springs
fuzzwaldo
hi
i am thinking about buying lowering springs and a tte front splitter but i am worried that it will catch on the ground and on speed bumps.
does anyone know if this will be a problem as i have to go over speed bumps to get into work
thanks
hi
thanks
If you have a prefacelift cts then the front splitter replaces the oe black plastic strip, and is probably about 10mm lower than what you had before (no idea what happens with a pre facelift cts though). And as for lowering it, unless you spend the money and get coilovers, then you won't get springs that will drop it low enough for speed bumps to be a problem. I have both the front splitter and lowering springs and have never had any problems with speed bumps.
