Hi
found the forum and really pleased to come across the TTS conversion. I wanted to PM Joe but it won't let me so I thought perhaps it could be public!
I missed the issue on the Aygo and wondered are there any back issues available? Could the article be scanned in and links pasted?
I'd really like to know a bit more about the conversion (TTS seem short of staff today)
- does it lower compression ratio?
- what's the boost level?
- if only a fuel computer and 4 injector are used isn't too much spark advance an issue under boost?
thanks!
You should be able to PM me -- plenty of other people have. Why not try again?
Anyway, the conversion was designed to work with the engine's standard internals. So the compression ratio is unchanged.
The boost level is set at approximately 0.7bar, which Rotrex calculated is within the working parameters of the engine's displacement and compression.
I have not experienced any problems with the engine under boost. I have used colder Denso Iridium plugs to ensure there are no problems with the sparks. In fact, the engine appears to relish being stretched right up to the rev limiter.
So far I have driven the supercharged engine for about 10k miles (including lots of motorway miles, track days and sprint events) without a single problem.
Hope this answers your questions.
Joe Clifford
Editor
Banzai
Joe Clifford
Editor
Banzai
thanks. i have pm'd you as it's working now. yesterday it said due to spamming i had to be a member of club to send pms
TTS conversion kit is great, but too expensive for a cheap car as the Aygo! If there isn't a reduction in price for the kit, i think nobody will buy it.
Some will buy it, but I do think that it's expensive. Still, it's tuning, the price is the same as the price for a more expensive car...
I'm considering it tho. I'll wait a while tho, have to get the cash for it first. And that's going to take a while.
I think kit price + aygo price you could buy a more powerfull car and it's a better way to have more hp :rolleyes:
  • 6 months later...
To Banzaijoe.
Do you know how many HP you get when you drive with 0,7bar ? and have you only driv with 0,7bar ore did you starte with a lower pressure ?
And wich rotrex supercharger do you have on your car ?
From Dan
Dan,
We used a Rotrex C15/16 supercharger and ran it at 0.7bar from the start as we'd already worked out the Aygo's optimal range by looking at the engine's displacement and compression ratio. With a fourth injector and a full straight-through exhaust system in place we figured the car with 138bhp at the flywheel.
Hope this helps!
Joe Clifford
Editor
Banzai
To Banzaijoe.
From Dan
Do you only have calculatede how many HP it will give ? Ore do you have any Documentation on the HP ?
and can the car not drive with out the fourth injector ? and how big is the exhaust system ?
i think they are going to yous the same supercharger on my Aygo :)
and thx for the answer :D
From Dan
