Help! Its Too Dark !
turbo_maniac_wayeda
Just realised the dash board lights and the heater instrument panels lights are all not working, what should i check? is it the bulbs? i checked the fuses they all seem ok, is this anthing to do with relay? i did accidentally leave the dim lights on at night and realised the next day around 1ish. but it was at night when i realised the lights are not working :( :angry:
i have recently replaced all my dash lights just because they got dim, prob just wear, they aint the best of bulbs, and can burn out very quickly and all of a sudden
Yep got it fixed now, one of the lights in rear passenger side had rain/water going into it and then build up which then shorted the circult which made the fuses blow.... also had the bulb connectors changed and fitted. :D Now working bright as a light :P
