Led Bulbs 4 Tacho (speed Dials)
blackpzs
Hello!
Does anybody know which type of led bulbs will fit here, what are their marks and specifikations
and are they all the same
They are all the same, I can't think of the name of them at the moment but it will come to me eventually
Today, in Toyota service, they told me that is impossible to remove just the bulbs, that they are "together" with that white plastic, so if l want to change the bulbs l must change the whole white table. Is this true?
The dealer won't sell the bulbs themselves.
I use RS Components for LEDS. If you go onto their website, it shows a wide range. You are looking for probably 12volt ones but try measuring the voltage at the LED just to make sure.
These panels are made up by components supplied intact to Toyota - we use a range of LEDs in some experimental light fitting; including electro-phosphorous panels.
www.rswww.com is the website
You'll probably find the LEDs are soldered into a circuit board.....unusual for them to go as they have a massive lifespan.
The panel comes out easily. Take it to a radio or ICE specialist who should be able to obtain the led's and solder them in for you.
I'll do it for twice the price and gie ye a guarantee fur 10,000 hours minimum. As fur yer life - thats up tae ye.
