Here she is now with her squareish plate
I’m still undecided. It doesn’t look ‘quite right’ I also think it is too far down. If the screws were about an inch lower so the plate was slightly higher then maybe. Will it affect air flow into the radiator seeing as its partially blocking the grill?
The Radiator on the Aygo is predominantly to the "nearside" of the engine bay (R/H side of picture) so I do not think a centrally located square plate would cause any cooling problems.
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
  • Aimee
    10
  • T V O R
    9
  • Jan van de Wouw
    5
  • Parts-King
    4
It doesnt actually cover the grill as the bottom of the plate is about 5 inches away from the inlet.
And as the aygo isnt exactly a BTCC spec touring car it hasnt caused me any problems so far.
:D
Did you just fancy a square plate then?
i was going to put mine the passenger side, and then have an air intake on the other side in the bottom grille! i think it looks spot on :D
