Scrape/grinding Noise
borodaz
anyone help me with this one ? sounds like a squeeky/scrape/grind noise
defo coming from front drivers side wheel area, sounds like something scraping on a disk brake, only happens when i turn to the right.
started very quietly when almost full lock, now its loud and occurs with slight turn to right.
ive looked at my disk and nothing is obvious, help ! lol
dont want to go to mrT and get charged hundreds for them just to find whats up, hopefully you great ppl can tell me whats up and then im half way there.
sounds like a wheel bearing to me?
jack the car up - spin the wheel, if the bearings gone it will be evident.........
Does the sound disappear when you reverse?
If so, then it may well be the brake pad guide (small silvery clip) within the caliper/pad assembly. All you'd need to do is replicate a brake pad change and if that is the problem it should be sorted.
You're right about not wanting to go with a dealer as it's around £75 nicker, and can be easily done yourself in a few minutes.
Had this on mine, and having other issues with the car at the time didn't want to risk voiding the warranty so had to bite the bullet. When I got round to fitting new pads was quite mad with myself at how I'd got ripped for an easy job.
Cheers.
seems to happen when it wants to now, need it checked asap, its raining so i aint doing anything today lol dont think ive heard it happen whilst reversing, i shall take wheel off tomorrow and inspect :)
i had this about 6 mths ago, it was corrosion on the brake discs and pads, mr t kindly replaced them under warranty for me
lucky you with your warranty lol
ive looked at the disk and it looks fine (no corrosion) cant see the pads properly so cant comment on them will have closer look when better weather comes.
