New Brakes Dics And Pads
robtheman
anybody had there dics and pads done and how much were u charged?
my cars done about 57k so prob did ok there but they are badly worn
did u want standard discs and pads? or aftermarket? ive got 3G brake discs and Brembo brake pads. i forgot where i purchased my discs from but the brake pads link is below
http://www.bremboshop.co.uk/product_info.p...ucts_id=1164130
heres the website of the 3g brakes, not where i purchased the discs but some info on them
http://www.3gbrakes.co.uk/main.htm
how much for two front corners for the set up you have ckman85 ? i have a feeling i need some new pads and disks as ive got a little problem.
im dnt quite remember how much the discs cost but i think it was bout £109 for the pair discs and the Brembo pads came to £79, DEF a lot betta than standard discs, but still not perfect so i mite get some custom brake hoses from Hi Spec lata on
i got grooved drilled black diamond with predator pads. £210 all in.
was this for two corners or just one ?
Toyota were asking for i think more then 300 supplied and fitted, discs and pads i went elsewhere and had it done for 180 front discs and pads and rear pads only. I think with discs at the back was slightly more bout 240 but still cheaper then toyota. Not sure which may go on your t sport but ik now my dealer was a rip off!
The other halfs T sport is in for service and MOT, it's done 22,000 mls and is on an 02 plate, they have just rung me to say that the pads are all low and it needs new discs all round, the fronts are below min thickness and the rears are scored, so it will fail the MOT when they do that, they want £301.63 front and £274.34 rear inc fitting plus a 60k service at £372.16.
Have told them to finish the service and I will get the MOT done at my local garage, what a rip off ! .
I don't understand why people continue to use Toyota for their servicing, it really doesn't make any sense. The argument is that a FDSH is better than a FSH when it comes to selling just doesn't cut it. Because they overcharge by at least £100 per service and with the resale prices of T-Sports, those hundreds of pounds will massively outstip the extra money you would get when selling it with dealer service history.
And as you have just shown Andy, any additional work above and beyond the overpriced service is extortionately priced. It was a sensible decision going elsewhere as you should be able to get all 4 corners fitted with uprated discs and pads + an MOT for sub £400 (there is however a really good guide on this site for replacing discs and pads on a T-Sport which I used and saved myself the cost of a mechanics' labour).
Toyota really shock you if you leave your car with them. In general all dealers do that but toyota the last time i took my car in it was due for a service and its first MOT
toyota worried me with the small modifications i carried out by changing my wheels saying they had major buckles in them which were not road worthy, saying how my engine oilwas to much and how it had to be cleared out the engine a few other problems and this was the time when i needed my brakes changed.
They gave me a service report which stated i would fail my MOT for tyres having low tread when they had more then 1.6mm all around all 4 and also brake discs severly worn etc and also the buckles in the wheels.
Infact i said no thank you ill take it elsewhere i was suprised to inspect my aftermarket alloys and find no buckles, nothing at all.
My car passed a good few weeks later in the same condition from a MOT place who deal with porsche, shocking !
Got the MOT done at my local garage for £35 instead of the £576 that Toyota wanted, had an advisory to say that the rear disc's were a bit scored but would never have failed on that unless they were cracked or worn out, they also said that I should have got Toyota to do the test and then fail it, then I should have reported them to VOSA, can't be ars*d to do that but they will lose all of my business, as I buy most of my Hilux Surf parts from them.
hi guys, ive just had fensport drilled and grooved discs (black diamond) front and back and ebc greenstuff all round
discs were 250 and pads approx 100, fitting cost me £80
So all in (fitted) £430 ish - Expensive but worth it and they look awesome!
