When Does The Vvti System Starts?
fatboyr
on my car (1.6) ive noticed it pick up alot more eagerly at about 3800. Try it on light throttle.
Ya its about the same on my 1.4...
anyone knows when does the vvt-i start working? so smooth that i didn't feel it.
The toyota system is continuously variable, not like the Honda Vtec with 2 cam settings.
Toyota reference http://www.toyota.co.jp/en/environment/com...lossary_02.html
VVT-i, or continuously Variable Valve Timing with Intelligence, is a technology that achieves high power output, low exhaust emissions, and high fuel efficiency; this technology optimizes the valve timing by using computer control to continuously switch the intake valve opening/closing timing according to driving conditions. Nearly all of Toyota’s gasoline-powered cars use VVT-i.
Honda 2 stage VTEC system http://world.honda.com/automobile-technology/VTEC/
Honda 3 stage VTEC system http://world.honda.com/HDTV/news/2005-4050705b/
so it's somehow different with the sudden change of VTEC, but when does it has the best performance?
i was under the same impression about the VVT-i system thinking that is does the same thing as the VTEC. I was wrong. It runs continually and you can hardly tell any difference. If you are keen on felling a small kick during acceleration change your air filter with a KN panel filter or a Typhoon system. You will feel the kick....a small one.
has anyone felt this? or is it just me?
My 1.4 is pretty much a tortoise when it comes to mid range power but I am very happy with the low range and high end power. thoughts?
anyone knows when does the vvt-i start working? so smooth that i didn't feel it. :P
2 months ago, I added the K&N filter and I feel like the car has been freed on the low range rpm while on the high phase it accelerates easier and the sound is much more attracting. I think that the vvti is most noticed from 3.800rpm and higher! You feel it on the gas pedal B)
