Wiper Noise
fatboyr
the wipers keep hitting on the windscreen frame when it comes down, anyone know how to fix that?
have you just put new longer blades on?
if not then then really you just need to undo the bolt, and take the blade arm off and then you see if you put it back on 1 turn round the bolt, it will sit higher and be better, give it a try.
not the best description but i dunno how to explain that lol
Collin
Collin
it was just the same set on it, but i just had enough with that noise. thanks mate. ;)
but unfortunately, the bolts were too stiff that i didn't manage to undo it... then i also found that there are some clearance for the rotational parts that's why it often goes too much
