2004 2.0 Td Won't Start
G L M
Had the rocker cover off a 2004 2.0 T D today had to unplug the injectors with Battery disconnected will they req re programing as the car won't start now, fuel is getting up to injectors and all pipes and wire's are connected
Any help wecome
Had the rocker cover off a 2004 2.0 T D today had to unplug the injectors with battery disconnected will they req re programing as the car won't start now, fuel is getting up to injectors and all pipes and wire's are connected
Any help wecome
hello GLM
why did you open rocker arms cover -- it is the first question;
secondly -- all injectors are being sprayed diesel under the control system command that give an el impulse to each injector solenoid.
i do not conside you'd program it.
pls come back/Igor
