Sensor I Think On Top Of The Dash?
rich1976
cleaned inside the car other day and found some sort of sensor in front of the driver ontop of the dash board ? just in front of the windscreen .
anyone know what its for ? 2002 t sport .
cheers
what does it do exactly ??? as it fell into the dash (through the hole) couldnt get to it so just plugged up the hole with a gromit ....
prob need to remove the radio to get to it if i need to ???
cheers for any help ...
If it is a solar sensor (which I think it is) then it measures temperature for the climate control to work.
Should be fairly easy to get to if you take the radio out yeah.
