Couple Of Questions?
JGW1987
Just got a couple of questions i hope you can help me with. I need some uprated Speakers and was wondering if anyone knew how big the standard door Speakers were?
What induction kits have people got/had/recommend for the 1.6 4AFE?
Has anyone had any experiences with Toyo T1R's?
Cheers
i built my own induction kit for the 4A-FE engine.
the front Speakers will take 15" but you have to make your own adapter plate as the toyota one are held in by 3 rivets rather than screws.
Also, if you put any Speakers with a larger magnet on then you may get in the way of the window going down all the way, I had to add 18mm spacers on mine in order to lower the window and then i had to shave a bit of the plastic strenghtenings on the inside of the door card for it all to fit :thumbsup:
Collin
Its like toyota didnt want the corolla owner to put in uprated Speakers. I looked at the back ones instead and there
3 screw fitments and a b*#t@rd to remove lol. Found some kenwoods that i reckon my fit in the back though follow the link and let me know what you think ;
http://www.caraudiocentre.co.uk/product_m-...9ie_p-20189.htm
yes they may fit, i found it easier to get a standard four point speaker and drill holes in the plastic to match.
i actually took the interior trim off, this made the job a lot easier.
