New Fuel Injectors On A D-4d How Much?
Paul1234
Having read through the threads on my engine vibration issue on my 53reg it looks like its the injectors
how much to get them done at Mr T
hi
there are two good ways -- ask for Mr Parts King or official Mr Toyota dealer there.
thanks
hi.. just had 4 injectors replaced on my 04 avensis.. under warranty thankfully cause dealer said they cost 500 euro each.. thats without labour costs !!!
  • 4 weeks later...
I just had two replaced on my 54 plate £300 each, plus about 7 hours labour £1041 in total changing all 4 at same time would probably only add the parts cost another 600
To GIW,
I would be interested to know how your dealer came up with 7hr's labour work to change 2 injectors. You only remove (plastic cover) engine cover, rocker cover supply pipes & wiring loom to access injectors. Or did you have extra work carried out at same time, if I am right you only have to have injectors programmed to ECM via code number on injectors? Just wondering?
