New To The Avensis
podwin
I am thinking of buying a 2005 2.0 TD Avensis Estate from a Toyota garage.
I have seen it and it looks nice, is there anything I need to check in particular.
Martin
Martin
hi
before purchasiing - ask for al injectors testing.
good luck/Igor
Martin
hi
good luck/Igor
Really, it that a common failure?
It's only done 26,000 miles by the way, is that still a valid question on such a low mileage?
Martin
Oh yes, MPG, I see the official combined figure is 47mpg for the 2.0 D4D.
What do other diesel Avensis owners actually get in the real world?
Martin
Martin
Martin
check both injectors and fine fuel filter and do not forget to test heating plugs.
you'd better read many issues for the same engine to keep in mind.
cheers/Igor
Martin
im geting 37mpg in my 04 d4d avensis . i had all the injectors changed and new ecu .it was runing at a average of 47 to 50 before i had the problems with the injectors . the dealers still cant find wots wrong with it .
Take it from me podwin dont do it ! this is my fourth toyota and my last they are nothing but bother i have a Toyota avensis D4D with 125000 on the clock watch the gears and they tend to loose power i could go on but there,s not much point.
IF ANY BODY WANTS A GOOD CAR CHEK THE HONDA ACCORD CDTI 2.2 DIESEL . AND LOOK AT THE BLOGS ON THE OWNERS CLUB SITE . I HAVE A 2.0 D4D 04 AND THIS IS MY LAST ONE AS WELL . IM GOING FOR THE HONDA NEXT .
My 05 with 80k on the clock has been spot on throughout, clutch pedal got quite heavy about 6 months ago, replaced under warranty at 80k service. Light output on the dipped beam is mediocre at best, thats my one real gripe. I think the facelift models went some way toward addressing the headlight issue. I have been very happy with mine though. Its just the cost of fuel which is turning my head toward prius for my next Toyota.
