aledjones_lex@hotmail.com Posted July 1, 2008 Posted July 1, 2008 hey guys wondering if ya can help me out i have a 1996 carina e 1.6 gs with a misfire which i cant explain. i have fitted the usual stuff to the car like leads anjectors spark plugs cap rotor arm. the car has been plugged into with a diagnostics machine and no fault was found it was also comppression tested with good compression. the car only misses when warm and playing with the heaters sometimes causes mis fire to stop. any ideas
Mike Thompson Posted November 11, 2008 Posted November 11, 2008 hey guys wondering if ya can help me out i have a 1996 carina e 1.6 gs with a misfire which i cant explain. i have fitted the usual stuff to the car like leads anjectors spark plugs cap rotor arm. the car has been plugged into with a diagnostics machine and no fault was found it was also comppression tested with good compression. the car only misses when warm and playing with the heaters sometimes causes mis fire to stop. any ideasHiI seem to be having exactly the same problem. I've changed the plugs, leads, rotar arm, dissy cap. But I still have an intermittent misfire. Plus it moves between the cylinders so I don't think it's a injector problem. One minute 3 will miss then 2 then sometimes 4. Did you ever solve your problem? Any suggestions would be welcome.
jayzee787 Posted November 28, 2008 Posted November 28, 2008 HI there iv just had my carina back from toyota today it kept misfiring when it got hot i was told by toyota to use some injector cleaner first of all a few months back and this did cure it now they have changed the injectors under the aa warranty repair cover and problem solved. it happened with my last carina aswell and i bought some recon injectors but they were no good it just seems to be a common fault as they have weak injectors
Toyota Official Store
Sponsored Ad
Toyota Model: Toyota Store
Toyota Year: 2024
