Valve Cover Gasket Replacement
Evets Vent
93 Camry, V6 Engine, 157,000 miles. The valve cover, nearest to the firewall is leaking oil. So, the gasket needs to be replaced. I was able to get to the valve cover, after removing the intake plenum. However, a wiring harness runs across the top of the valve cover and I can't find a way to move it to gain access. Can anyone tell me how? The Toyota dealer want about $450.00 to do the job!!
I'm not familiar with that car.. but usually you can trace the loom along and undo it from various sensors or multi plugs, and lift it clear!!!
most plugs are "fool proof" so you can;t reconnect them wrong... -but if your not sure mark them with different colourd bits of tape :)
