Wheels
Lee 1
Just wondered..... Has anybody else got the same problem with the standard wheels on they're Yaris T-sport 'flaking?' <_< Its seems as though it started through stone chips...... :angry:
Lee
Lee
take it back get new ones under warranty,
hi
lee
my tsport did the same on all 4 make sure that you check all of them
what year is yours mine is a 02 52 plate.....
oh yeah say hello to South Shields for me.....
Corossion which may be causing your flaking is quite common with all Toyota/Lexus alloys, there are not many that don't, older ones tend to be re-finished. It's something to do with because they tend to polish them rather than laquer them - either that or because they tend to be made in Italy.
hi
lee
Hi there, mine is 02/51. Ive only just noticed it whilst i was cleaning them the other day. Gutted!!! :angry: Would they be covered under the warranty?
Anyway do you know South Shields well then???
Lee
I know of people with saxo's and clio's that have had this problem aswell, and they got changed under warraty. Unless they've been kerbed?
They will be covered on Warranty....I'm on my third set!
First set pitted badly on all four corners...second set the
front two started pitting...but I insisted they change all four
which they did....then I asked em to change the front one again,
as it was damaged on the rim when they put it on!
Vipes
Yeh, I need to visit a dealer soon as mine has just reached the 2.5 years mark and I need to get all my odd & ends sorted before the warrenty runs out.
My wheels are a bit ropey and show flaking and corrosion - I've only kerbed the rim of one of the alloys and the corrosion is near the hub on that wheel.
Well touch wood I aint kerbed them in the 2yrs ive had the car, so I may get them to check the problem out when I take it in for its full service in February.......
hi
lee1
oh they will take a few mouths for them to arrive well mind did anyway hope you sort your wheels out soon.
as for south sheilds is where i was born i try to seem family once a year if i can they live round mortimer road area.
