Fun With Headlight Repair
dagbladet
Standard (phase 1) headlight. Failed MOT as the beam was too high and the adjuster didn't work, guy offered to price a new headlight unit, declined as I decided to have a go myself and change from scrappy if necessary.
Long story short
2 hours to remove headlight
5 minutes to un-seize (made up word) the adjuster
2 hours to replace headlight, bumper, under tray, wheel arch liner, wheel, plastic bit inside bonnet.
Remaining in hand - 1 x 10mm metal bolt/screw, 1 x black plastic stud thing, 1 x white plastic stud thing, 2 x broken plastic stud things, 1 x MOT pass.
That's got that off my chest. :hammer:
Long story short
I had a headlight removal sequence in an earlier post. May have saved a few knuckles! Not sure if you could have removed the adjusters, without the extra work of removing headlight! I take it you cant remove the light though, wothout the bumper? In the Haynes book, it says remove but then, they would! :P
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
