Avensis Turn Ign Key Then Nothing
Laird
Avensis y reg. I turn ignition key and nothing. Have removed casing aound steering column, if I waggle wires about the engine starts. Any ideas what it might be.
Welcome to TOC
Bad connection / broken wire. Start by making sure that all the connectors around the steering column are good and tight.
If you do not feel too confident about fixing it yourself a trip to a local Auto Electrician may be the best bet. :thumbsup:
Ingnition switches on Avensis are famous for failing, buy a new switch, about £50 ish
Kingo :thumbsup:
Kingo :thumbsup:
Yes,changed a couple myself.
Kingo :thumbsup:
Same thing happened to me. Was intermitent fault, so I traded it in for a newer Avensis. ;)
