Wheel Squeak
ho8day
Hi everyone hope someone out there can help with this one.
I have a strange squeaking noise coming from offside front wheel that occurs on every revolution :unsure: , when i apply the brakes tho it goes away and when i lift off it starts again. Taken the wheel off and looked around the disks and pads but cant see anything out of place. You can even hear it when the wheel is off and you turn the hub manually, although it sounds more of a rubbing sound then. Anyone got any ideas.
Much appreciated :D
Have you checked your wheel bearings lately?
No. How do i go about doing that? will i need to do both sides?
