St202 - Brake Bleeding Sequence
razza987
Hi guys, first post :D
I'm working on a mates ST202 Celica 2.0 GT.
I need to bleed the brakes, can anyone tell me what the recommended sequence is?
Also, do you have to bleed the ABS unit and if so how?
Cheers, Raz ;)
Usually the sequence is to bleed the brakes starting with the wheel physically furthest from the master cylinder and finishing at the nearest wheel. If you've had one wheels brakes disconnected then bleed this one first, then do all four in the order above.
