Oil Cooler Radiator Leak?
leachy
Hi everyone just noticed a oil leak on the little rad that is in front of main rad on my 1.8 r reg avensis.Are these any easy item to replace and where can I get one from other than an original as I 'd expect a pretty penny for them !!Many thanks for any help on this matter !!! ;) Cheers Leachy
hello Leachy
it's understood this coil might be repaired by soldering having dismanted it. Another solution -- DevconA plastic steel or an alternative that are also available on the markets. Of course the best solution is to change this radiator. There're three ways as above that must be considered by YOU only.
Good luck
Igor
