Silly Sat Nav Question
nuttygt4
Silly Question, but my mate has just bought a 54 plate T-Spirit, but we couldn't find where to put the Sat Nav disk in, the screen just says insert DVD ROM, I though there should be a box in the boot?
Could someone shed some light?
Cheers
Cheers
Mine's under the passenger seat I think...
You need to slide the passenger seat as far forward as it will go, then go to the back door and you will see the sat nav unit under the seat. There should be a protective plastic kick guard to stop damage to the unit. Release this by the 2 plastic pins and then insert your new disc and be sure to close the disc cover before you switch on the ignition. Bingo, your in business!! :D
