Corolla Airbag Warning Light
motfesg
My wifes 52 plate corolla air bag warning light has come on. the dealer says the NSTK airbag sensor is faulty and needs to be replaced - cost £427 inc vat for fitting - the part is apparently £355. Does this seem right.
i can give you the code to reset the airbag light, then you can see if it comes on again? dealer might be trying to pull a fast one.
please do - its worth a try - thanks in advance
don't know - the paperwork says N/STK sensor, airbag £300.55 each - part Y89170 - 02180 - might be the whole airbag assembly. Will get it done next week - don't want it going off or not going off.
I think it's the main airbag ECU. Still expensive, but better than being quoted that price for just a sensor..
