Air And Pollen Filters
richard price
It has probably been asked before but how does one change (is it easy) the air and pollen filters on December 2006 Rav and rough cost of filters. Thank you
Hi mate, dont know about the air filter but there is a pinned topic above for changing the pollen filter.
Have a look in the maintnence and tips section. :thumbsup:
here you go, see link -
http://toyotaownersclub.com/forums/index.p...;hl=maintenance
http://toyotaownersclub.com/forums/index.php?showtopic=69757
Hello Richard,
The air filter is a doddle.
Open the bonnet. The black plastic housing labelled air cleaner case in the diagram has 3 shiny silver clips on it. two on the right and one on the left. Pull them back and the top of the housing should come loose. Lift the top up a little (the air outlet hose may restrict its movement a bit) and you have access to the filter. lift it out and pop in the new one. Redo the clips. 2 minutes max probably.
I paid about £18.50 minus about 10% discount plus VAT from Mr T for my last one.
