Replacing Maf Sensor
marcus007
Just a short question mates,
Should one reset the Ecu after replacing the Maf Sensor with a new one ?
Hi, I think the ECU is a self learning type, so you just need to drive the car for a while for it to operate correctly.
BTW, why did you change the maf? was it faulty and if so, what were the symptoms? Many thanks. Gar. B)
