D4d Lumpy Idle
rob virgo
Is there anyone who has had an issue with a lumpy idle on a 04 2.0 d4d avensis.i checked the engine mounts and they appear to be ok.it seems ok when reving and driving.
cheers
rob v
cheers
rob v
hello ROB
what's milage reached after the last engine service??? What are RPM when idled run? Are they constant or jump??
Send more details by return/Cheers/Igor
cheers
rob v
hello ROB
igor ,
serviced it last week and no change (oil and filter only)
@120 k on engine
revs at idle @ 850 to 900
constant revs but vibration evident
cheers
rob v
cheers
rob v
hello ROB
igor ,
@120 k on engine
cheers
rob v
ok now all is clear.
the possible reasons:
- injection timing;
- fuel valves solenoids control signal delay/or wise versa;
- poor injection;
- fine fuel filter clogging.
when diesel is poured but not injected the engine works harder but at the same time it maintains designed rpm.
check with the above remedies first & advise the result.
good luck/Igor
cheers
rob v
hello ROB
igor ,
@120 k on engine
cheers
rob v
- injection timing;
- poor injection;
good luck/Igor
tks igor ,
i can only see the fuel filter as the one i can check myself.
any tips on the others or is it a garage job,have the gear andnot to bad at spannering.
cheers
rob v
cheers
rob v
hello ROB
igor ,
@120 k on engine
cheers
rob v
- injection timing;
- poor injection;
good luck/Igor
tks igor ,
cheers
rob v
fuel filter can be changed by you -- but be sure that you will escape an air from the system thru special screw located on the lid (it's easy to locate it)+ pay attention to prevent destroy of all rubber O-rings when assembled. each destroyed O-ring is a source of air sucting into th efuel system.
all others must be checked by reliable garage.
please alert once all have been rectified + state the result.
good luck/Igor
igor ,
have changed the filter which hasnt made much difference.
the vibration comes and goes.
clutch is now slipping and after a little serching it appears if the duel mass flywheel starts to give out it gives the vibrations i have been seeing.wonder if they are connected
cheers
rob v
cheers
rob v
hello ROB
igor ,
@120 k on engine
cheers
rob v
- injection timing;
- poor injection;
good luck/Igor
tks igor ,
cheers
rob v
good luck/Igor
igor ,
cheers
rob v
Hi Rob V
Before a flywheel dismantling -- you'd better check the injectors.
I've heard that dual mass flywheel is common problem but it takes a lot of time to rectify.
I'd start from injectors.
ANy other opinions here???
Cheers/Igor
