Hi everyone
Anyone know how to get to the plugs on my 92 privia???
Hi everyone
Under the drivers seat is an inspection cover and through this you can get to the plugs. You will need to unbolt the seat, remove the jack housing, remove the plastic door skirt, unhook the carpet holdowns, move back the carpet and undo the 10 or so brass bolts.
NOTE !!!!! the plugs only need to be changed every 60,000 miles and with the correct platinum tipped plugs.
