Error Code 51- Help!
flyingtele
I have just put a straight intake on my car, and also removed the throttle body to clean it thoroughly. After reassembly I fired the car up, and it idled for about 10 seconds and then just died. I know there is a vacuum leak due to a crack in the intercooler, and I'm going to repair that. But then I decided to check for ecu error codes, and it spat out 51, which means no aircon or IDL signal, and relates to the throttle body.
What I need to know is how do I fix this? How do I adjust the TB to its correct location?
