Hello,I have a Previa(92)which I only got a couple of weeks ago and hey presto I already have an electrical problem.Everything was working fine until I got in yesterday,the first thing I noticed was that the internal lights were not working.Then I discovered that the small overhead clock was not working and just to add to my woes the lock/unlock switch on the drivers door had also given up.all 3 things packed up at the same time.I checked the fuses(3 different ones)which seemed to rule that out. So can anyone HELP,BEFORE I TAKE IT TO A GARAGE TO HELP PAY FOR THEIR SUMMER HOLIDAY. Thank You.
  • 5 months later...
[/did you ever find out what the problem was, because my previa has just done the same thing.
  • 2 years later...
Hello,
Mine also has the same problem - did you find the answer please.
Thanks,
John
