Distance Control
artisticka
:help:
Very good Morning brothers and sisters,
I wonder if there's a way to turn the distance control sensors off. Is there switch/wiring etc anywhere that could turn this annoying beeping sound off/on?
Thank you in advance.
God bless.
Artisticka
xxx
:D
No sure if its standard or just coz I asked, but in the boot on the left side about rear shelf level there should be a button to turn off the reversing sensors.
Hope it helps
The switch is standard in the Verso. If you ever want to tow anything or fit something like a low bike rack you have to be able to turn the sensors off. So I would think it is part of the sensor kit.
If the sensors are fitted before delivery then they usually have the on/off switch fitted already.
If the kit is retro fitted at the dealership then unless they have ordered the cancellation switch seperatly then it may not be fitted as the switch isnt part of the kit, its an additional part.
As said above - if the switch is fitted then its usually on the nearside of the boot area. Its a small round black thing - not always easy to see.
Mart.
