What Oil Do I Use?
GT-FOURNZ
going to do an oil change but unsure what oil i should use and how much do i need so could some1 plz tell me what oil should i use 4 the engine, gearbox, transfer case and rear diff.
thanx in advance
thanx in advance
For the Engine you need a 10W full synthetic oil like Silkolene Pro S 10W50 or similar.
The Transfer case fills as part of the Gear box as does the Front diff.
As a result of this you need to use a 75W API GL5 grade gear oil such as Silkolene Syntran 5.
For the Rear diff on a ST205 the same as above for gearbox, deffo not an LSD oil as it's a gear type diff, the 185RC/CS is the same not sure about a stock 185.
ok cool cheers mate. how much do u reckon i will need all up?
Engine is about 4.5Litres gearbox/Trans/Front diff(all fill from gearbox) is 5.2litres rear diff 1.1litre.
  • 4 weeks later...
