Do You Like My New Seats?
GIDDLEPIN
Very nice Les :thumbsup:
They look comfortable and should be kind to your back....................are they?
They look VERY smart Les...
However, I'm more interested in knowing how you managed to get a shot of your car in sunshine with the top down this summer! :)
They look even better in the flesh Les. B) Very Nice. Door cards will certainly finish the effect off.
Nice upgrade Les :thumbsup: Looking good :yes:
jerry!!
Hi Les - They look great with the bodywork colouring. I've also got the red cloth trim inside mine and it's beginning to look a bit grubby. If I wanted to give the interior a really good clean is it a big task to remove the seats especially with the electrics. Someone told me to disconnect the Battery due to the air bags going off if I disconnect the cabling plugs.
Thanks in advance for any replies :thumbsup:
Hi Les - They look great with the bodywork colouring. I've also got the red cloth trim inside mine and it's beginning to look a bit grubby. If I wanted to give the interior a really good clean is it a big task to remove the seats especially with the electrics. Someone told me to disconnect the battery due to the air bags going off if I disconnect the cabling plugs.
Hi TK thanks for the comment :thumbsup:
To remove the seat....
Push right back.....Remove two front bolts
Push right forward.....Remove two rear bolts
Lean seat over and disconnect plug underneath......................................Job done ;)
Just reverse the procedure to replace :yes:
Les
I've never heard of this before, otherwise i'd of had second thoughts about taking them out when re-doing my stereo :D But all they are, are simple pressure sensors and have no affect on the airbag as they use crash sensors in the front bumper.
