Part Number For Lowering Springs
malpass
After ringing toyota they cannot even tell me what springs I need to lower my celica. I have told them I want the TTE springs, and even springs off a VVTLi, or springs that lower the car 30mm. I told them they are standard on the sports version of the car and everything else, and basically all they can do is get a list of part numbers of springs, with no information on them as to their size, what they fit or anything else...
So, can anyone tell me the part number of the springs I need to lower my celica 2000 by 30mm (been told they are called TTE but that doesn't help me), or have a registration number for a celica that has those springs as standard?
Also, possibly the part number for some shocks to match too.
The Part No. for TTE Springs is PZ439-10721-00. These Springs are designed to work in conjunction with the standard Shock Absorbers on a Gen 7 so you've no need to change them. The Springs on a 190 or T Sport will not lower the Car so are no good to you.
If Toyota are still struggling, let me know and I'll get a GT Reg. No. for you.
Brilliant thanks; so just to double check that number is for the springs that will lower my car 30mm (its a 2000 reg standard VVTi)
AFAIK, the actual drop is 26-30mm :)
