Headlights Misting Up.
alexaurisTR
Hi.
My headlights mist up when its wet, i noticed it when i cleaned it yesterday.
Is this ok or can something be done? :huh:
Hi.
They steaming up on the sides??
Mine do it too, i think its normal
If there is a little steam at the dull parts, the side part that has no practical use, I believe it is normal because I've seen such small spots on other brand cars too. Of course, if it goes away after 10 minutes of leaving your headlights on. Sometimes it happens to me too, if it's cold outside. It's at the side part and about the size of a fender flasher(you know, turn signal) Never happened in 4 months though, it's like hell in here.
Although if it's a massive mist build up, which covers in front of the lens and high beams, that's probably because the headlight case is not air proof as it should be. You can take it to the dealer and they can air clean it up and seal it properly.
thanks for that.
Its just to the sides, and it went after about 15mins.
I'll stop worrying now. :thumbsup:
